Need help with a repower on a 22 Glacier Bay cat. The Yamaha 90C manual the local dealer sold me is not helping with the wiring, leaves me a bit confused, as the harness doesn't match the book.
New (2006) twin 90TLR two strokes, wired as two independent systems. Have a pair of PROII series analog tach/trim gauges, separate yamaha key switches, and harnesses with all the wires seeming to color match well, but I don't have a yamaha remote control binnacle. I need to somehow connect harness wiring to a pair of existing remote trim switches and figure a way to wire the neutral safety switches in the morse MT3 binnacle to the key switch/harness wires. The main harness to the key switch has an unused 6 conductor plug that has red, blk, lt blue, lt green, and two different shades of brown wires, some of which will connect to the trim switches, but it seems I'll have to cut the connector and splice.
Is there a yamaha connector that I can use to the existing six wire main harness connector to operate separate existing trim switches? Or should I opt for the yamaha dual trim switches 704-82563-F0-00 (is this correct number) and would that contain the proper connectors?
Where does the neutral safety switch splice into, guessing one or both of the brownish colored wires on the main harness six conductor connector?
Have the following:
6Y5-83553-N0-00 Gauge Harness (2 fuse)
6Y5-83653-20-00 Trim Harness
6K1-8258A-40-00 10P/Main/Harness/26ft
704-82570-08-00 Panel, Main Switch A
6Y7-83670-40-00 PRO Series II Trim Gauge
6Y7-83540-80-00 PRO Series II Tach Guage
Any type of schematic or wire diagram for 90TLR would be greatly appreciated.
Have the following:
