Hello... Was wondering if anyone here had experienced this problem. My father has a 2003 Yamaha 115HP 4 Stroke motor. When he slows down and goes into either neutral or reverse the motor kills. Then you start it up and go to reverse it kills. Replaced the computer, reset everything, new wiring harness. You drive down the river and then slow it down and go into reverse and it dies or you go into reverse it dies there also. Neutral switch has been replaced also. If anyone has any experience like this or suggestions could you please drop me a line at: skids1@fiai.net
2003 Yamaha 115HP 4 Stroke problem
Have had this problem since engine new-(2001)- only way to stop it was to set idle to 900 rpm. No longer cuts off but scrapes a little more going in gear from neutral. None of part changes or shop fixes while under warranty worked. Also had problems with idle speed pulsing on occasion when idling after cruising speed.
Â
