Another trim gauge question.
  • Another trim gauge question.
    I have been tryiing to install a trim gauge on my 06 Alumacraft. I found the pink wire and black wire at the engine that is coming from the trim sending unit. The only pink wire I can find under the dash goes to the fuel guage.
    Do I tee into the pink wire at the motor and run a wire up to the dash for the gauge?
    Any help would be greatly appreciated!
    2006 Alumacraft Trophy
    2006 Yamaha 200HP four stroke
    Analog Faria gauges
    No the pink wire under dash is for warning buzzer. You will need to install 6Y5-83653-10-00 Trim/Oil harness, connects to trim sender on engine and goes to trim gauge. You may have change connector on gauge end of harness(pink wire) to match terminal on gauge.
