retrofitting '04 F15C (non-electric start) to charge boat battery?
  • retrofitting '04 F15C (non-electric start) to charge boat battery?
    I have a 2004 Yamaha F15MLHC (tiller sterring, non-electric start) outboard. It is used as a *****ing motor on a larger boat. I would like to find out if it is possible to convert this to charge the boat battery. This could be a potential life-saving feature.
    When I purchased new, I remember the dealer telling me that it could be converted at a later date. I called the dealer this week and they said a kit is not available.
    I may also use this on an aluminum fishing skiff at a later time (when I simplify my life) and battery charging would be needed and electric start would be handy.
    There are no kits available. You can add a rectifier(6G8-81960-A1-00) to charge a battery but would require some wiring. You can buy all the individual parts to add elect start.
    6G8-81960-A1-00 1 RECTIFIER & REGULATOR ASSY
    6G8-82150-00-00 1 FUSE HOLDER ASSY
    97095-06016-00 3 BOLT
    92995-06600-00 3 WASHER
    6G1-81952-00-00 1 HOLDER, RELAY
    6G1-81941-10-00 1 STARTER RELAY ASSY
    66M-82105-00-00 1 WIRE HARNESS
    66M-82117-00-00 1 WIRE, LEAD
    65W-8182B-00-00 1 NUT, SPECIAL
    95380-08700-00 1 NUT
    92990-08600-00 1 WASHER, PLATE
    6H3-82540-00-00 1 NEUTRAL SWITCH ASSY
    6J8-82554-00-00 1 STAY, NEUTRAL SWITCH
    90109-06M86-00 2 BOLT
    65W-81870-00-00 1 STARTING SWITCH ASSY
    66M-81800-01-00 1 STARTING MOTOR ASSY
    90119-08M39-00 1 BOLT, WITH WASHER
    90109-08M78-00 1 BOLT
    90109-08M85-00 1 BOLT
      Thank you for your prompt answer to my question. The solution looks expensive, but at least it is possible.
