I purchased a used boat with twin 115hp's that has the Yamaha Fuel Management System. Unfortunately, there wasn't a user's guide or manual with the FMS. I found a post on how to calibrate it, but, I can't seem to find any instructions on how to operate it. Can anyone help?
fuel management system--user's guide/manual
To reset it?
About the only thing you can do is reset it to zero when you fill up the gas tank. To do that just turn the ignition key to the "ON" position, do not start the motor, then push the two buttons down together for a few seconds. You'll see the totalizer reset to zero. Other than that just cycle through the MODE button to pull up whatever's available. If its not connected to your GPS or Speedometer output you won't see any other info other than gallons per hour and total fuel burned since reset.
-Mike
Originally posted by eskimokim View PostI purchased a used boat with twin 115hp's that has the Yamaha Fuel Management System. Unfortunately, there wasn't a user's guide or manual with the FMS. I found a post on how to calibrate it, but, I can't seem to find any instructions on how to operate it. Can anyone help?
Originally posted by Hamfisted View PostAbout the only thing you can do is reset it to zero when you fill up the gas tank. To do that just turn the ignition key to the "ON" position, do not start the motor, then push the two buttons down together for a few seconds. You'll see the totalizer reset to zero. Other than that just cycle through the MODE button to pull up whatever's available. If its not connected to your GPS or Speedometer output you won't see any other info other than gallons per hour and total fuel burned since reset.
-Mike
Yes move the fourth dip switch in back of gauge to down position for liters, up for gallon's.
Need maual also
Could you please send me a Yamaha Fuel management system manual as well. Thanks FishingB bfbarnes@usa.net
Need manual also
Could you please send me a Yamaha Fuel management system manual as well. Thanks Jim jd1king1@q.com
CaptainRande@yahoo.com
yamaha fuel management system operation manual
Originally posted by JUST-IN-TIMEemail me
i can send u the owners manual
rmayhall01@bellsouth.net
Yamaha fuel management connector wire codes
I need the wire color codes for the S type plug out the back of the FM gauge. I have the harness that plugs into the plug. It looks like red, black and white. That happens to be the same colors as my pigtail harness out of my Humminbird 1157c I am connecting it too. Help!
brett@marinenutz.com
Need Manual
Just-In-Time,
Did you have a link to the manual for the Yamaha Fuel Management System? Thanks. rmajor11@cfl.rr.com
Fuel/Speedo and Digital Tach
Can you please send me the manuals also, I just had the dealer install them and no paperwork came with them. email to von21a@comcast.net thanks!
ÂÂÂÂÂÂ
