Own twin 1998 2-stroke L200s. Engine oil tank not refilling. Found a defective harness. Also, oil pump not working. Replaced both. Initially connected, not working using toggle. Works fine on other engine. Would question the toggle but shouldn't oil pump work when engine is running, even if toggle was defective. Also, when I first connected the new parts. the toggle worked and I ran the engine a few times on long trips and the engine tank was refilling fine. Last trip, oil lights went off, engine tank was empty, remote tank full, toggle wouldn't activate pump. Manually filled engine tank, green light. Switched engine tank tank sensor and it works fine on other engine. Don't know what else to test. Any ideas?
