I've got a Yami 225 Salt Water Series- The engine turns over and will run only if I spray starting fluid into the throttle body, but as soon as the fluid burns off, the engine dies- So it will not idle. I replaced the fuel/water sep filter, cleaned the fuel filters before it hits the low pressure pumps and cleaned the high pressure pump filter as well. All the filters were dirty- but clean now. I checked the voltage at the high pressure pump and its showing 12v when the engine is cranking, but no fuel is coming out of the pump. Any suggestions on cleaning the pump? or is the pump dead? Any info is greatly appreciated.
Nick
Nick
