Originally posted by outdoorsman
View Post
tiller to remote question
96 Conversion
Originally posted by boats.net View PostYou would need
6L2-48501-11-00 Remote attachment kit
689-61350-02-00 Steering guide attachment
6J8-48511-51-4D Steering Hook
703-48230-15-10 Control Box
order 2 control cables, MAR-CABLE-xx-SC(replace xx with length of cables needed)
For the key switch and choke to operate from control box you would need:
(1)6L2-42725-50-00
(1)6L2-86111-00-00
(1)682-86117-00-00
(1)6L2-86115-00-00
(1)98580-05008-00
(2)92990-05600-00
(1)90480-10155-00
(4)98508-04008-00
(4)92990-04200-00
(1)6L2-86112-00-00
(3)97013-06012-00
(3)92990-06100-00
(1)93210-03261-00
(1)6L2-82590-00-00
(1)6K3-82557-00-00
Leave a comment:
Do you still have the tiller arm for the 2007 Yamaha 25 that you were converting to remote steering.
Alan 970-470-3613
Leave a comment:
Yamaha Tiller arm
Originally posted by dcc134 View PostI have a 25 hp elect start 07 yamaha on a carolina skiff. I want to change it to remote steering ...My motor is 25ESH ..serial 6L2K S 1024831....What parts do I need to make this conversion.....should I add engine gauges to the console?....I know that there is a steering bracket that attaches to motor that I can't find..Where do I get that bracket......I'm pretty handy...What tools do you need to make this change? ...I have a good Idea, but I want to make sure before I buy....would I need a Remote Conversion Kit?
Do you still have the tiller arm off the 2007 25 HP motor that you were converting to remeote steering>
Alan 970-470-3613
Leave a comment:
On the 25 it normally has a couple feet of harness and control box harness connection is outside cowling.
Leave a comment:
what do I do?
I have question about the wire harness.....When you connect the remote end and the motor end of the wire harnesses, is the final connection inside or outside of the motor cowling.....how are the wires run if the the connection is inside....do the parts that you listed above include parts that seal off the motor from water???????
Leave a comment:
I have question about the wire harness.....When you connect the remote end and the motor end of the wire harnesses, is the final connection inside or outside of the motor cowling.....how are the wires run if the the connection is inside....do the parts that you listed above include parts that seal off the motor from water???????Attached FilesLast edited by dcc134; 07-22-2009, 07:56 AM.
Leave a comment:
I found it, 6K3-82557-00-00 supersedes to 6G1-83557-00-00 it is plastic sleeve that covers the wires.
Leave a comment:
If you look at this post, this is the number that you gave me...
http://www.yamahaoutboardparts.com/f...on-th7347.html
Leave a comment:
Originally posted by jeff180 View PostI've got a new 25esh model #6L2KS 1042060 from y'all recently. What parts do I need to convert tiller to remote? I do not want key start or electric choke. Will the parts mentioned in the previous threads work for this newer model #?
Jeff
689-61350-02-00 Steering arm
6J8-48511-51-4D Steering hook
701-48101-51-00 701 Side mount control box
(2) MAR-CABLE-xx-SC throttle/shift cables
Leave a comment:
tiller to remote 25 ESH
Jeff
Leave a comment:
The Rigging Guide is the only source of information on control box installation. The control box installation is about the same except for electical and the main harness just plugs into harness on motor.
Leave a comment:
ÂÂ
Leave a comment:
