rigging guide
I bought a rigging guide off of ebay that was going to help me install my 703 7 pin remote control box, but its no help......what would be the best source of info for installing a 703 remote control box?
tiller to remote question
Originally posted by bguess View PostTiller to remote on Yamaha 30 MSHA - 6J8-S-112016
No electric start or choke wanted
just steering and throttle.
Regards,
Leave a comment:
Regards,
REMOTE CONVERSION PARTS
Leave a comment:
Same Question as dc134
Regards,
Leave a comment:
It's a 2007 25hp elect start, short shaft and tiller control.
Yamaha Outboard Parts 2006 and Later 2-stroke 25ESR 6L2K-1018361
Leave a comment:
Thanks for your help......Can you tell me where this model number comes from....ESH ...6L2K S 1024831....When I'm looking up parts this model number never comes up...the dealer tells me that it is a bad number.....I want to modify what I have already done....
Leave a comment:
No the 703-48207 is push to open throttle, 10 pin main harness with power trim switch.
703-48230 is pull to open, 7 pin main harness and no trim.
Leave a comment:
Remote question
Can you tell me if this remote will work with my 2007 25hp ESH ...6L2K S 1024831 Yamaha motor? part number 703-48207-17-10
thanks
Leave a comment:
You would need
6L2-48501-11-00 Remote attachment kit
689-61350-02-00 Steering guide attachment
6J8-48511-51-4D Steering Hook
703-48230-15-10 Control Box
order 2 control cables, MAR-CABLE-xx-SC(replace xx with length of cables needed)
For the key switch and choke to operate from control box you would need:
(1)6L2-42725-50-00
(1)6L2-86111-00-00
(1)682-86117-00-00
(1)6L2-86115-00-00
(1)98580-05008-00
(2)92990-05600-00
(1)90480-10155-00
(4)98508-04008-00
(4)92990-04200-00
(1)6L2-86112-00-00
(3)97013-06012-00
(3)92990-06100-00
(1)93210-03261-00
(1)6L2-82590-00-00
(1)6K3-82557-00-00
Leave a comment:
I have a 25 hp elect start 07 yamaha on a carolina skiff. I want to change it to remote steering ...My motor is 25ESH ..serial 6L2K S 1024831....What parts do I need to make this conversion.....should I add engine gauges to the console?....I know that there is a steering bracket that attaches to motor that I can't find..Where do I get that bracket......I'm pretty handy...What tools do you need to make this change? ...I have a good Idea, but I want to make sure before I buy....would I need a Remote Conversion Kit?Attached FilesLast edited by dcc134; 01-13-2008, 08:09 PM.Tags: None
Leave a comment:
