Fuel management
  • Fuel management
    i have a fuel management system i would like to add to my boat but there are no ends and my motors were hooked to analog gauges c, can someone give me a diagram or tell me how to hook this up thanks in advance.
    You need the gauge, harnesses and sensor.
    Gauge can be tied in with the power of other gauges,and lights, harness connects to the gauge and sensor/s and sensor needs to be tied into fuel line.
      i have all the sensors and wiring from what i can tell the green and green/white wire are for the tachs ,red power,black ground.and a yellow ?there are also 2 wires at the rear by the sensors a black and a red/white those i dont know.i have the gauge powered up and working but when i run the motors they do not show any fuel flow just 0.0 any help would be nice
        the open wires at rear are for a water-sensing seperator.
        yellow SHOULD be for constant power,( its been years since ive done mine).
        is your sensor inline w/ the fuel line??
        if so, unhok the lines and you should get a signal by blowing thru it.
          Try this site.
          http://www.shipyardisland.com/images...ll%20Guide.pdf
