F115 tlr 2006 - need wiring help
  • F115 tlr 2006 - need wiring help
    I have a 1999 boston whaler that had a 1999 f100 TLR on it. I have the original analog trim gauge and original tach, the tach has lights for oil an temp.
    I purchased a 2006 yamaha F115 TLR to replace the f100. It appears the old gauge wiring harness will not work to hook to new engine. Main harness works fine. Can I use the same gauges with an adapter harness of some kind? Do I need new gauges? thanks.
    The trim gauge will not work on newer motors and there are no adapter harness available to adapt older gauges to newer motors.
    The easy way is to order 6YR-W0035-E2-00 multifunction tach kit. It has tach, trim warning indicators and hour meter built into it and comes with wire harness for your motor.
      6y5-85335-00-00?
      Some reading turned this adapter harness pn. Is this to hook a new tach to an old motor?
        That is the adapter harness to connect 2001-2004 multifunction gauge to 2005 and newer engine.
