New to the Yamaha family, especially 4 stroking. 2 - 2006 115's. Changing the oil, what a mess, both from the drain tube and when I tried to do the filter. Any secrets or tricks? Extra hands? Does the cowl come off to do the filter? Fog or not fog? The 2 stroke I had, I used to disconnect the fuel and run the motor 'til it sputtered, fog intake, then do cylinders. Can't find a fuel shut off or disconnect. Should I yank it off the filter body on the engine? Or just squirt the intake and shut down? The only literature I have is the owners manual. Not helping me right now...it is getting cold quick, the rut is on and I'm running out of time. Which manual should I buy?
Any input will help, I did a bunch of reading here and you guys know your stuff.
Oh yeah, one of the plastic clips (on the bracket) that contact the indicator for the trim of the motors broke. I replaced it and now the trim for the 2 motors doesn't match. Any adjustments needed (on the gauge) or did I not install it in the right spot?
