Tilt & Trim
  • Tilt & Trim
    How Do You Check The Gauge For The Trim,the Switch At The Motor Works
    Check for 12 volts and ground at gauge, if newer than 2001 you can jump across black wire and pink wire with key on and gauge should read full trim. If you good power and ground and gauge reads full when jumped then sender is bad.
