The Yamaha Service manual does not show any thread lube on assembly of the heads and water jackets. A local "ole timer" advised me to use zinc anti-seize on all threads during re assembly. The book also indicates a torque spec of 22ft/lbs. I am assuming that this spec is for non lubricated, dry s.s. bolt onto aluminum threads.
Any ideas on the question about torquing lubed threads as opposed to dry threads. In aviation, there are lubed specs and dry specs.
Any input is appreciated.
