Gettin ready to de-crud all the water jackets and heads. Bead blast or chemical like CLR ?
I plan on using Loctite "chisel" to remove old gaskets, any known issues with that product.
Does the yellow coating in the jackets need to be recoated??
I have 2 very stuck head bolts... do I heat the head of the bolt (then let cool) or the surrounding thread area?
The thread areas are in amongst other gasket surfaces.
While doing this PM I plan on new t-stats & PRV.....anything else??
I took tons of pictures of the removed parts showing the crud if anyone is interested. I removed the water jackets and heads and only broke 4 bolts and have 2 very stuck....not bad huh?
Thanks guys........
Thanks guys........
