I Have A 90 Norriscraft 1900xl With A 92 Yamaha 200 Vmax The Motor Idles Fine And Runs Fine Untill You Back It Off Of Full Throttle. It Has A Slight Miss Then You Can Push The Throttle On Down And It Goes Away Also What Should The Rpms Be. It Has A 24p Throphy 4 Blade Prop I Have Only Had The Boat For About A Year I Have Never Seen Any Rpm's Over 4800 At That Rpm The Boat Seems To Run Fine And Pretty Fast.any Help Would Be Appreciated THE MOTOR IS A 92 PROV200 NOT VMAX
92 Yamaha 200 Vmax Miss At 5/8 Throttle
