Have you investigated the fuel pump isue mentioned earlier. If the fuel pump gets its pulse from 3, and I think it does, a pin hole in the pump diaphram can cause this problem. The leak may be small enough to have little effect at higher RPM.
There are hoses on the crankcase cover to control the pooling of raw fuel at low RPMs. be sure you confirm this system if working properly.
This type of ignition system incorporates a start up timing advance for easy starting. When the engine is started the timing is advanced for a few seconds and the RPM is raised. When the timing retards, you can hear a drop in the RPM. I'm wondering if this is the point when the engine stalls. If so, I look closer at the linkage setup or CDI box. When the engine stalls, can you instanly restart it and have it idle fine for another 15 mins. (resetting the starting timing advance)?
I remember the Pro 50s with this ignition, you had to wait for the timing to retard before shifting to avoid lower unit damage.
