Sometimes my motor will not shutdown. I turn the key off and it will not shut down I pull the emg. stop and it still does not shut down. This may happen about every three stops I make while fishing.
1998 150 will not shut down sometimes
engine harness, main harness or key switch. The white wire is put to ground to shut off the engine. Ohms check the white wire. Usally on the engine harness on old Yamahas the cover didnt fit well and water gets in engine pan.
ÂÂÂÂÂÂÂÂÂ
