Overheating in this OB occurs about 2 min after engine starts, water pressure on the pee hole is good, but water comes out hot.
Is there any way to check water pump pressure before proceed to replace it?
Is there any other component that will produce overheating like the thermostat?
Could any water passage be clog and still water comes out of pee hole?
Thanks much!
Thanks much!
