I get all my parts from boats.net & found this most informative forum, keep up the good work guys.
I live in the caribbean & service for outboard motors is very limited.
I have triple 250hp outboard ox66 on a 35ft wellcraft Scarab we do snorkeling tours when the Cruise ships visit. Luckily the boat can still work with 2 engines.
The problem is after running the boat at say 3500 rpm for 10 minutes one of the motors shuts down & will not restart. Will crank but will not fire & start back for sometimes 2 hours after it has shut down. Will start back in 2 hours & run at any speed even top speed perfectly & after 10 minutes shut down with out any warning & willnot start back for another hour or 2.
I thought it was a fuel problem & have changes all fuel filters including the high pressure fuel pump filter.
It seems to be something heating up. I have changed water pump impeller, both thermostats, replaced pressure control valve(is this suppose to move freely in the rubber seat? as mine rubs the seat a bit). I changed the impeller because the flow of water through the pee tube is very weak. When I put the garden hose on to the engine to flush the engine without starting there is hardly any water comming through the pee tube. When I do this with one of the other engines the pee tube squirts lots of water, something seems to be restricting the flow of water in the cooling system in the engine. I removed one powerhead to check the condition of the water passages in the head & head cover & they were in very good condition no blockage looked like new. Put the head back on with new gaskets engine started on second crank & the same broblem ran for 10 minutes & could not be started until 2 hours later. When the engine is running no alarms go off before it shuts down.
If I happen to have picked up some sand in the water intake, as our sand in the caribbean is like powder fine how do I get it flushed out.
One ore thing I forgot to say is I have a water pressure gauge on each engine & the engine that is giving this problem, when the boat moves off to get up on the plane the needle in the gauge almost goes up to the top reading for 5 seconds & flips back down half way & then gradually comes down quarter way on the gauge just about at the same reading as the other 2 engines. This is some sort of pressure build up & then releases, if you run the motor with out thermostats you get no pressure reading on this water pressure gauge but the engines still shuts down after 10 minute run.
Maybe if I fix restricted water flow problem the engine may not shut down.
Did a diagnostics check on the motor at idle all sensors are fine. Could one sensor be overheating & shutting down the engine? I have 2 other engines I can switch a couple of sensors over & if it happens with the other engine we will have the problem nailed. What are your thoughts on that as well.
As you can see I'm willing to try anything at this point in time. Look forward to hearing from you folks, if I was in the U.S I would have many options but I am in the caribbean only one dealer for yamaha & they are very busy so whatever advise I can get from you folks will be greatly appreciated.
