3 wires tilt retrofit
  • 3 wires tilt retrofit
    Hi
    Does anyone knows how to change my 3 wire to a 2 wire trim/tilt?
    I have a 1985 175HP and I changed the mid-section with a newer model mid 90's. It came with a trim/tilt motor with 2 wires and I can not figure out how to connect the 2 wires. I did conect the blue and green but all I get is the solenoid click sound. I did test the new motor ans it works fine. Do I need new solenoids? please help. Thank you.
    You will have to change trim relay to one that matches the year model the power trim is off of.
      Today I went back and got the missing relay box, problem solved. Thanks.
