1994 130 need rigging help
  • 1994 130 need rigging help
    Hi,
    I am new here. Could anyone help me identify or locate parts #s for rigging? I am looking to aquire a tach/speedo with harness as well as a key switch. From what I read the rigging seems to change around 1994.
    TH
    Which control box do you need side mount or top mount(binnacle)?
    Which gauges analog or digital?
    Do you need the oil tank?
      I have a top mount control box with a main harness to the engine....thats it. I am looking for a digital multi gauge and a speedo gauge. Also I need a key but I think this plugs into the gauge harness...which I need.
        704-82570-08-00 Switch Panel
        6Y5-8350T-82-00 Multifunction Tach
        6Y5-83570-S5-00 Multifunction Speedometer
        68F-82553-90-00 Trim/Oil Harness
        6Y5-83553-N0-00 Gauge Harness
        Set dip switch in tach to 2 stroke engine, 12 pole alternator and 3 wire trim sender.
          Thank You!
            What part number is correct for the oilt tank kit? I am looking @ one with a 6E5-13437-43 yamaha part number.....is this on track??? Thanks
              6YR-W0035-92-00 3 gallon oil tank kit with harness and hose.
                So...6E5-13437-43 would not work? What is that tank for...any clue?
                  6E5-13437-43-00 is just a decal.
