I have twin 150 OX'66s, model year 2000, with the digital yamaha fuel management system and I have a few questions:
1. should an alarm sound momentarily when the ignition switch is turned to the "on" position but prior to starting the engine?
2. when i turn the key for the starboard engine to the "on" position, all gauges power "on". When in turn the key for the port engine to the "on" position, only the port engine tachometer comes on. Is this the correct operation?
3. For both engines, the trim indicator gauges do not change when I trim/tilt the engines. The port engine is at 80% and the port engine is at 50%. Any thoughts on what is causing this?
Thanks,
Thanks,
