1999 Yamaha 70
  • 1999 Yamaha 70
    I am not getting any spark. changed the plugs. Looked at a fuse I found it seemed good.
    in neutral, kill switch lanyard on ??? if so then could be bad kill or neutral stop switch in throttle box.
      1999 Yamaha 70 2- stroke
      Yea - it was the lanyard... oops should caught it.
      Right now the motor makes rpm with the muffs on in the driveway but it won't go over 22 hundred under a load (in the water).
        Right now the motor makes rpm with the muffs on in the driveway but it won't go over 22 hundred under a load (in the water). Thanks
          Your carbs need to be cleaned.
