Greetings -
Frustrating problem with overheating on a 2004 F225. Motor has 2,000 hours on it -
At idle speeds, very low water flow coming from weep hole, and motor overheat alarm will sound after about 30 seconds of idle. At higher speeds and on plane, will run fine all day long.
Actions so far:
Acid flushed the inside of the motor twice to remove any deposits.
Replaced water pump impellor (old one was still good).
Checked thermostats per the service manual and both operate fine.
Checked PRV valve and appears fine.
Have lots of water flow coming from the pump - ran the motor briefly without the PRV valve in place and had lots of flow. Removed one of the internal zincs between the spark plugs and had very little flow coming out of there. I'm suspecting a clogged water passage somewhere - but hoping there is an easier approach to checking all the passages without trying to tear down the heads first. Any suggestions?
Does anyone know the exact water flow sequence in the motor? I'm hoping to disconnect hoses at various points and try to isolate where the blockage might be.
Thanks.
Tom
Actions so far:
Thanks.
Tom
