150 hp Vibration
  • 150 hp Vibration
    I have a 2000 150 Carb Motor and about 1100 RPM which speed I use for *****ing I picked up alot of vibration from the motor,Carbs?
    hey okee, you need to run motor on the hose, pull each plug wire at a time and listen for a non firing cylinder/no sound change. The same can be done by removing airbox and choking each throat with your finger and listening for an an increase rpm or smoother run.
    carbed motors are known to get clogged.
    hows it run up hi ??
      check the obvious first tho,... prop , prop shaft and compression.
