Still have this problem: 1999 40HP. At wot, runs fine for a few minutes, then loses power (5500 rpm to 5000rpm). If I throttle back, it will surge and run fine for another few minutes. If I do not throttle back, it will continue to lose power and stall, but start back up.
I have: Rebuilt carbs twice, changed fuel pump, filter, tank, fuel line, fuel, plugs, prop, fuel lines, gages. Now oil alarm goes on for no reason, but turns off if engine is tilted up then down. (sometimes). Oil sensor seems to be OK mechanically.
Should this engine become a mooring, or is there hope?
