I have a pair of 2002 225HP four strokes and I can not remove the starboard engine lower unit. I tried prying, banging, jolting the power head etc. but it appears the shaft is stuck. The port unit dropped right out but not this one. Any advbice?
stuck lower unit
Hi, this may sound like a dumb Question, ...but are you sure that you did not forget one bolt? After doing the starboard motor, I moved on to the port moter,and forgot to remove one of the bolts, and the lower unit would not come down, so I took a break. When I went back to it, I realized the problem, and removed the bolt.
Dennis
