I have a 2 cycle oil inj 25 hp yahama. On the lake yesterday after running for about 30-45 min wide open, my motor all of a sudden dropped RPM's and would rev up and down without mounting any power. It would only run at idle speed. Also when in neutral when I would attempt to inc the throttle it would rev up and down. Things of note, red light indicator on, motor didn't seem excessively hot, tell-tale working, new water pump installed about 6 mo ago, oil in resevoir, gas line bulb not not firm. After fishing for an hour or so started up, initially no light on and got to full throttle for about a minute or so, same thing happened again.
Where to start? fuel problem? oil injection? Why red light on? Thermostat problem? Is this protective mechanism as so not to overheat motor?
Thanks,
Chad
Thanks,
Chad
