c115 Engine won't turn off.
  • c115 Engine won't turn off.
    1997 C115 had intermitant spark issues, thought I traced the problem to the key switch assembly.
    Purchased a new switch from this site,engine starts
    fine but after several start/stops it wont shut off.
    I turn the key off and she keeps running.
    Pulled the kill switch and it still runs too.
    I think it may be a ground wire issue in my wire harness. I order the shop manual to see schematics.
    Any thoughts guys?
    Thanks, its a great site.
    Probably the main wire harness between engine and key switch has a broken ign. stop wire inside harness or the CDI unit is bad. Try replacing the main harness first.
    6X3-8258A-00-00 16ft 10 pin harness or
    6X3-8258A-10-00 20ft
    6K1-8258A-40-00 26ft
