My question is if it is safe to run my outboard (F40) with the “ears” attached to the lower unit water intake? When I flush the lower unit at home, no water comes out of the little hole in the upper unit. I want to make sure that I don’t damage the impeller. I understand that the only safe way to flush the impeller and lower unit, is to use those “ears”. Thanks, Gerhard
Flushing F40 lower unit question
Make sure the flusher fits tight on lower unit, the gear housing is very narrow and the flusher will slide off water inlet screen letting water pump run dry.
not sure about lauderdale area but sometimes if im lazy after bein in salt, i will back down into a freshwater ramp and run for a few mins....rinses trailer at the same time.
if water from the spy does not exit e' better not to make to work the motor, with the caps not us they would have to be problems, controls the water capacity of the tube
byGianni
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
