trim/tilt
  • trim/tilt
    When I hit my trim/tilt switch down it clicks but does not work. When I hit it up it works fine. If I use the trim/tilt switch on the remote it does the same sequence. Is this just a switch gone bad or could it be the trim motor? Yamaha 250 Thanks
    Test the relay with a digital multimeter, see if it's passing voltage through it when you hit the switch. Could just be a bad relay.
    -Mike
      Thanks for the responses. Is the relay between the switch and motor? I tried looking on the parts diagram but cant seem to find it. Thanks
        Its the thing you hear clicking.
        It's under the hood, on the port side of the powerhead.
        -Mike
          What is the switch part numbeR?
          I have a Yamaha 200 and the remote lever switch is having a hard time going down on the switch... the switch on the motor works 100%... its just the remote lever one...
          anyone have instructions on how to change this out? diagrams would be great
          thanks!
