Isolated charging lead??
  • Isolated charging lead??
    Does anyone know the charging current on the isolated charging lead of a 225 OX66? How it changes with rpm?
    The user manual says 35 amps for the engine. How is this split between the main and isolated lead?
    It has a built in isolator which is regulator. It allows most of the charging current to go to the battery with lowest charge until battery's are equal then both battery's recieve equal charge, it would split the 35 amps between battery's.
      Thanks for info...
