After sitting it will not start without pumping and pumping the ball. Then most of the time it still doesn't. A quick one step squirt of ether in the carbs and it starts. Once running there is no problem.
Is it normal that after being idle the ball is almost always totally empty of gas? Doesn't seem right, but I installed a new ball with no change.
I ran carburetor cleaner through with no help.
Used clean external gas can with no help.
Any suggestions as to my next step?
