I have a 2004 Yamaha F225TXRC outboard motor. When I first turn the ignition key after the motor has set for several days, nothing happens. After turning the key on and off several times, the motor will turn over and crank. It cranks fine the rest of the day. Batteries and connections are good. Could it be the ignition switch or motor starter relay?
Yamaha F225TXRC Starting Problem
