My '88 Yamaha 115 2 stroke is extremely hard to start after it has set for a few days. However, after it finally starts, it runs great and starts up fine the rest of the time on the water. My Mercury 115 that I had on my old boat started right up. I have tried pumping the bulb until it was firm, choking, etc., with the same results. I have also tried only pumping the bulb once or twice with the same results. What do ya'll think? The engine has not been used very much at all over the years and it has plenty of compression, no fuel leaks, plugs look to be in good shape (I did remove and clean them). Should I install new plugs?
'88 Yamaha 115 hard starting
Thanks J.B. It looks like I need to check my throttle plates and make sure they are closing all the way when I choke it from the driver's seat. Thanks!!
an 88 model 115 is not a primestart motor and you should raise the throttle some. hold the choke in while starting and maybe even bump it a few times after it starts if it wants to die.Michael Babuchna
Well, I did what ya'll said and it was still very hard to get started. Maybe some new plugs would help? I fished for about and hour or so and when I got ready to leave, it was hard to start again. Could the priming bulb be letting the pressure down too much? All these components (plugs, bulb, etc.) are several years old.
ÂÂÂÂÂÂÂÂÂÂÂÂ
