my buddy got a new maverick hpx recently. the boat originally had a yamaha four stroke 90hp installed. he had the dealer switch out the motor to a yamaha 90hp two stroke. the boat is a pocket drive hull and he has been having a major problem with cavitation. when the dealer switched the motor he used the prop from the four stroke. my buddy got that replaced last week with the proper prop according to maverick specs (what the dealer says), but he is still having the cavitation problem though not as bad. he went from a 19 pitch to a 17 pitch or vice versa maybe. will lowering the motor on the mount help with problem? when you look at his boat the motor seems to sit high so the shaft is not that deep in the water. would anyone have recommendations to help solve this problem.
thanks,
mike
thanks,
mike
