1994 Yamaha 90 HP Trim System
  • 1994 Yamaha 90 HP Trim System
    Do you really need to lift the motor off the boat to get out the back bolt on the trim motor?!
    Brit
    Most definitely. No shortcut that I have ever heard of. You may be able to lift it off the boat just enough to get to the bolt but you still need to lift the motor.
      YEP JUST NEED TO SUPPORT TO TAKE THE WEIGHT OFF OF IT
        Not what I wanted to hear but thanks for the info! It would be nice if the manual mentioned it! Thank you
          sometimes u can use a tree. or put blocks under the motor to support it
          u do not need to take fully off
          some guys take the clamp bracket off one side to get it to swing out
