I have an 86 ProV 150. Motor starts and runs good but when it's idling but I get a misfire about every 5 to 10 seconds. This causes the rpm to drop and a fine mist to be sprayed from the bleed system. The spot that the mist eminates from is on the starboard side behind the top carburetor, (this hose comes from the bottom right (starboard) cylinder. Checked all carb and timing adjustments, everything seems fine. Anbody have any idea what it might be?
Thanks,
Craig
Thanks,
Craig
