I'm having som trouble with my c150 overheating. I can run at idle speed for long periods of time w/o any problems but once I go full to almost full throttle the engine will overheat after about 1-2 miles distance. I just got the boat from the shop where they replaced my water pump & thermostat's but I'm still overheating.
When my rev limiter cuts the RPMs and a go to idle the water sitting out is not even Warm it's much like the temp of the water i'm in.
What else could be causing the overheating if my water flow seems to be in order? Could the thermoswitch's be bad or the alarm sensor?
Any tips would be greatly appreciated.
