MULTIFUNCTION GAUGES
  • MULTIFUNCTION GAUGES
    CAN ANY TELL ME WANT THE WHITE W/BLUE STRIP WIRE ON THE BACK OF THE SPEEDOMETER GO TO ?
    ALSO ONE GRAY WIRE ON THE BACK OF THE SPEEDOMETER
    AND ONE GRAY WIRE COMMING OUT THE PLUGON THE BACK OF THE TACHMETER
    The white/blue wire is the fuel sender wire for fuel gauge(connects to pink wire from fuel sender in boat). The gray wire needs to connected to gray wire in harness to make temp light work.
      IF The white/blue wire is the fuel sender wire for fuel gauge WHERE does the white wire go?
      do you have a pic of the wiring they you can e-mail me ?
