Motor run good for about 100 yards, then the rpm drop and the motor begin to miss fire,then caughting and going good, but started miss-firing every once in a while. Going back to the dock I went down to ldle speed and the motor cut off and will not start. Could this be foul plugs, gas is new filter change. HELP!!!!!
2001 Yamaha 25 4 stroke
I suspect fuel contamination leading to blockage of
your carb jets. Same thing happened to me 4 times
this season. Despite cleaning my tank, using stabilizers and cleaners, it kept fouling up. Some
people say it is due to gasahol. It doesn't take
much to plug up these tiny jets on the smaller four
strokes. Yamaha recommends a 10 micron filter inline with the fuel tank. I am installing that plus a water seperator filter and a new fuel hose.
If that doesn't work, I give up.
