I have a 1991 90 HP. At top RPMs it reverts to idle speed and the hot horn comes on. It runs fine at medium RPMs all day. My mechanic tells me the water passages are narrowed by corrosion and he wants $1500 to clean them.
My neighborhood, part-time mechanic tells me that this can be cured by flushing a weak acid solution through the system.
Can anybody tell me if this is a valid solution and how it should be performed?
Thanks.
Thanks.
). Zinc cromate is the replacement coating? I tried CLR on some smaller components (stat housings) and it removed the crust without removing the coating but I'am chicken/reluctent to use it on surfaces I can't see. The factory coating is yellow I believe.
