HI HOW IS EVERYBODY,MY MOTOR HAS PROBLEM AGAIN!! it was happen after motor run about 45 mins, and then stop for other 30 mins, and then run about 20 mins,and then suddenly the motor was loss power and rpm was drop down to 800,so i was put the control back to neutral and put forward again then the motor was dead!
so i started the motor again and every thing just back to normal,run about 5 mins,samething again!and then happen 3 time after,i took off the build in fuel tank hose with vapor filter and plug in the 2nd w/o vapor filter removable tank,and then all run good~_~ so is it mean need to replace the filter?my filter beem replaced, but it beem uesd about over 150L of fuel through that filter already,is time to replace again? also fuel pump replaced plugs replaced 2cyc oil full and the carbs was cleaned very nice start right the way and whatelse it could be! if you guys have any idea please help..please help
Thanks in advance for any help ..........pls
/2uNNe/2
/2uNNe/2
, but hopefully not.
