I have twin 1998 250hp OX66 fuel injected motors with Yamaha gauges. The gauges don't register fuel consumption at *****ing speeds below 10kts. Is there an adjustment other than the 1-3% adjustment on the back of the gauge? Should I be looking at the relay, hoses, or something different?
Fuel gauge doesn't read at slow speed
you mean on your fuel management gauge...mine does the same thing..i would GUESS there may be a air pocket/bubble slowing or not allowing the spinner inside the sensor to turn or as we`d expect. mine are installed at a high point in the lines and might allow for an air pocket. i have cleaned mine before but if you pump the ball or rev it it registers right away.if you get it figured out please post your fix for us !
JB123...are your bulbs mounted before or after the sensor? According to the rigging book, the configuration should be tank-filter-sensor-bulb-motor. My set up has the bulb between the tank and filter but before the sensor and I'm wondering if that's allowing air bubble and causing a false read.
