My "new to me" 9.9 electic start (2000) will stall at idle ( unless idle is turned up quite high... too high for comfortable shifting), and will continuously surge. If I put it in gear ( and it doesn't stall) it will run smoothly at high revs, but stall at low throttle.
I have replaced plugs, auto choke, and fuel. The carb has been cleaned twice and the fuel pump seems to be OK. Could this be a timing problem? I have been at this for 3 weeks, and nothing seems to correct the problem.
