The alarm came on before I lost the head gasket. Replaced Head gasket, alarm is still on, indicating low oil. Checked pump on resevoir tank, replaced oil injection sensor(not sure of name) on the bottle attached to engine. Alarm is still on. Engine starts perfectly, idles perfectly, but surges when in gear (automatic shutdown is activated). Cleaned O2 sensor, cleaned all filters, and checked and cleaned filter in high-pressure fuel pump.
while in gear, I can pick up speed to about 3200 RPM by pumping throttle, but only lasts a few seconds before cutting back down to 1800 RPM. Checked all visible wires with tester. Alarm still on.
Hooked engine up to computer. Response: check cables between engine and battery. Checked and replaced cable...alarm still on
I have been working on this problem for about two weeks. I hope someone can help.
Earl Poole
Earl Poole
