200 hpdi cuts out at 3000 rpm
  • 200 hpdi cuts out at 3000 rpm
    I have a 2000 Yamaha 200 HPDI. The engine cuts out at 3000 rpm. It runs fine up to there. No alarms go off. I have replaced the plugs and fuel filters. Any other suggestions?
    did you check your sensors to ensure all are working and buzzer buzzing?
    when it cuts out does motor die or drop down in rpms?
      What do you mean by cuts out? Stalls out completely with the buzzer going off or bogs down w/ no power? I had a problem last year where it would start to bog severely and gas consumption would sky rocket. The problem was a loose o2 sensor. It was sporadic about 70% of the time.
      Good luck, Ed
