Hello,
I'm brand new to this form because I bought a boat with a Yamaha. I never owned this brand before and things are different on this brand then other engines I've owned.
The engine is a 2002 Yamaha 250... SX 250 TURA.. hours 1274
The other day I started the engine up in the driveway after a few minutes an alarm was going off. I looked at temp guagage and it was going up. I shut engine off. I did some research on this matter and I came up with the Poppet Valve spring. I took off the valve stretched the spring and reinstalled. I started the engine and I have no alarm and after 10 minutes of running no signs of overheating and no water leaks from the poppet valve.
The other day I put the boat in the water and pushed off I started slowly push the throttle down and the Alarm went off and could not get passed 7-9 knots. I limp the boat back to the dock and back home. At no time did the temp go up and Pee flow was very good. I did some more research and it looks like the Engine went into Limp Mode.
The other day I went out to check out what's going on and when I turn the battery switch on and turn the key over the alarm is going off and the engine is not running.
The location of the alarm is under the ignition key.
I will say I have not done anything to this engine at all... no time right now...
Thx in advance.
Sabotage
Thx in advance.
Sabotage
