Hi,
I have a 2010 Yamaha 25hp motor. I recently had the dealer do a gearcase
service. The motor came back leaking lube at the drain plug. The dealer replaced the red washer on the plug with a black washer which he said was an improved product. We talked about the possibility of an old washer still in the
case or damaged threads or gasket seat. Within a few hours after arriving at home, the case was still leaking. I returned to the dealer and asked that the
cause of the leak be identified before doing anything else. One day and a half
later they called to say they used an "O" ring and in that day and a half there was no leaking. When I picked the boat up I fingered the drain plug screw head and there was oil residue on it. The attending employee opined perhaps it was residual. A possibility I thought. Upon arriving home I cleaned the plug with solvent until it was clean. the following morning there was a puddle of lube under the skeg and the plug and skeg wree wet . Any ideas as to the cause? The dealer has been very accommodating but I'm afraid that something untoward may have occurred during the gear case service. Thank you in advance for your professional opinion.
Tony
Tony
